Civil 3D Forum
Default water drop layer?
3 REPLIES 3
1826 Views, 3 Replies
Every time I go to use the water drop tool on a surface I have to change from the default layer 0 to my 'water drop' layer.  I'm sure there must be a way to change it but I couldn't seem to find it in the surface styles...
3 REPLIES 3
Jeff_M
Toolspace->Settings->Surface->Commands->CreateSurfaceWaterdrop, right-click, Edit Command Settings, Water drop path....
owenmull
Yes, there is.
Go to Settings Tab-->Surface-->Commands-->Right Click 'CreateSurfaceWaterdrop'-->Edit Command Settings-->Expand 'Water Drop Path'
Here you can set the default layer from '0' to whatever you want.
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
in reply to: owenmull
Fantastic.  Thanks, I managed to change it by toggling the "Save Command Changes to Settings" to 'Yes', then creating a water drop under my specified layer then going back and toggling it to 'No'... but this way is MUCH more straightforward
Smiley Very Happy
Thanks again
Rail Community
