Civil 3D Forum
Daylight points list
0 REPLIES 0
Message 1 of 1
97 Views, 0 Replies
Hi
I would like to produce a list showing, for each section, the northing,
easting and elevation of the daylight points (and other codes). I used the
corridor > export corridor points as cogo points and then generated a report
using the "Point List" form. However, that report doesn't show the
correspondence between the points and the section (number or pk) they were
extracted from.
In short, I need an extra column in the following table reporting the
section number. Is there an easy way to do this?
Number
Northing (m)
Easting (m)
Elevation (m)
Description
1
8580.900
19836.292
558.755
Daylight
2
8605.819
19838.309
562.842
Daylight
3
8626.848
19838.750
565.647
Daylight
4
8630.852
19838.796
566.153
Daylight
61
8580.900
19836.292
558.755
Daylight_Cut
62
8605.819
19838.309
562.842
Daylight_Cut
98
8778.774
19822.926
572.325
Daylight_Fill
99
8784.323
19825.429
572.638
Daylight_Fill
Thank you
Luis Vasconcelos
PORTUGAL
0 REPLIES 0
Rail Community
