When I created sections for a corridor, I noticed that the proposed corridor
surface line stops just short of the existing surface line in a cut or a
fill situation. Then I did some investigation work (I zoomed in on the plan
view of the corridor, and noticed that the proposed contours did not connect
with the existing contours - also the cross hair display shows that the
elevations from the existing and the proposed surface are different).
Any ideas? Is it because the proposed surface is only accurate to a 1'
contour?
Thanks for any insight
Alan B
