I edited the daylight in the corridor sections so the grading would work, but in the plotted sections, there are a couple where the datum shows correctly, but the daylight line is in the origianl 3:1 slope location. I've attached a screen cap showing it. The purple line is the datum & the red line is the daylight.
Any idea why it does this?
I've seen cases where section views will display older versions of a corridor and not update properly. Try deleting the section from the sample group and then replacing it with a new copy.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Hi Steve.
I tried that but it didn't work. It's been escalted to a support case, so I'll wait to see if AutoDESK knows what's going on.
Chris
Jason at AutoDESK looked at my drawing & determined that the corridor was corrupt. A new corridor worked fine.
