Civil 3D Forum
Daylight Slope Trasnsitions - SubAssembly Composer
6 REPLIES 6
KPerison
1963 Views, 6 Replies
I know I've seen a video or post recently about transitioning cut or fill daylight slopes over a station range.  I'm pretty sure it was a workflow using Subassembly Composer to do some math by figuring out the required slope at each section then pass thast slope on to the daylightlink.
I cant remember if it was an AU video or from youtube, but can't seem to find it again.  Has anyone seen this video or post.
SAC2013
6 REPLIES 6
sboon
in reply to: KPerison
Perhaps you're thinking of this thread.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
KPerison
in reply to: sboon
Thanks sboon,
I did see that post from Peter. However, we dont have 2014 yet, so I am unable to extract any of it's goodness 😞
I have also used your profile workaround method previously as well.  But I know there is a video out there somewhere that spells it out pretty clearly so it can duplicated with SAC2013.
KP
Nik-D
Is this what you want?
KPerison
in reply to: Nik-D
Thanks Nik-D,
Yes I had seen those examples as well.
I just happened to stumble upon the video I was thinking of.  It was an AU2012 lecture (the last one I hadn't looked at).
It was decieving because the class description doesn't mention anything about slope transitions.
Approx. 49min. in he begins to describe the process.
Here's the link: CI2281
Nik-D
Its guarenteed that the thing your after is always in the last place you look 🙂
KPerison
in reply to: Nik-D
**Correction**
He starts explaining the process around 42:30 and ends at 58:00.
Rail Community
