I know I've seen a video or post recently about transitioning cut or fill daylight slopes over a station range. I'm pretty sure it was a workflow using Subassembly Composer to do some math by figuring out the required slope at each section then pass thast slope on to the daylightlink.
I cant remember if it was an AU video or from youtube, but can't seem to find it again. Has anyone seen this video or post.
SAC2013
Solved by KPerison. Go to Solution.
Perhaps you're thinking of this thread.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thanks sboon,
I did see that post from Peter. However, we dont have 2014 yet, so I am unable to extract any of it's goodness 😞
I have also used your profile workaround method previously as well. But I know there is a video out there somewhere that spells it out pretty clearly so it can duplicated with SAC2013.
KP
Thanks Nik-D,
Yes I had seen those examples as well.
I just happened to stumble upon the video I was thinking of. It was an AU2012 lecture (the last one I hadn't looked at).
It was decieving because the class description doesn't mention anything about slope transitions.
Approx. 49min. in he begins to describe the process.
Here's the link: CI2281
