AutoCAD Civil 3D General
Active Contributor
Message 1 of 4 (151 Views)
Database
151 Views, 3 Replies
05-27-2010 10:22 AM
I have a survey drawing with pts and a surface in the database. If I open a another drawing file and xref this survey file into it, how do I link this new drawing file to the database the survey file was using.
*Matt Kolberg
Message 2 of 4 (151 Views)
Re: Database
05-27-2010 10:31 AM in reply to: wvu9494
By database, do you mean the survey database? Surfaces don't exist in the
survey database, they exist in the drawing file. Points can exist in either
the drawing, the Survey database. You can link points between drawings by
using the survey database. You can link surfaces between drawings by using
Data Shortcuts and Data References.
Matt Kolberg
Global CADD Systems - A division of Cansel
Active Contributor
Message 3 of 4 (151 Views)
Re: Database
05-27-2010 12:44 PM in reply to: wvu9494
Ok thanks. Sounds like thats one major difference (of many many) between Civil 3D and LDD. LDD had a centralized data base where all drawings could be link to to access all project information (surfaces, alignments, pts, etc)
*Srayos Endbringer
Message 4 of 4 (151 Views)
Re: Database
05-28-2010 05:59 AM in reply to: wvu9494
You really need to do the tutorials on Civil 3D. It will answer most of
your questions.
EB
Win7 Pro 64-bit
Civil 3D 2011 64-bit
6GB RAM
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
