AutoCAD Civil 3D General
Civil3DReminders.com
Message 1 of 3 (595 Views)
Data Shortcuts not Updating Properly
595 Views, 2 Replies
05-22-2013 11:36 AM
So I've got a customer who's upgraded drawings from a previous version of Civil 3D to Civil 3D 2013. One drawing contains data shortcuts to pipe networks, alignments, and surfaces. At the drawing open the pipe networks are updated, but none of the other data shortcuts are. Removing the pipe network data shortcuts allows the other data shortcuts to be loaded normally. Using SYNCHRONIZEREFERENCES updates all of the data shortcuts normally in the darwing. So I strongly suspect the pipe networks are the cause of the issue. Opening a new drawing and creating a data shortcut doesn't exhibit the same issues. Also WBlocking the trouble drawing doesn't work either. Any other ideas on a way to fix the drawing?
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Jeff_M
Message 2 of 3 (593 Views)
Re: Data Shortcuts not Updating Properly
05-22-2013 11:42 AM in reply to: Civil3DReminders.com
Does the subject drawing also have the PipeNetwork source drawing as an Xref? If so, unload it and see if that helps. This is what I found (thanks to Jay_B) to fix the multitude of issues I was having with DRefs.
Message 3 of 3 (560 Views)
05-22-2013 08:45 PM in reply to: Jeff_M
Thanks Jeff. That is the issue. It does appear reattaching the xref after unloading appears to not show the same behavior. Not quite sure how long it will last though.
Civil Reminders
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
