rkmcswain
Message 1 of 7 (480 Views)
Data Shortcuts and moving C3D projects to new server
480 Views, 6 Replies
01-22-2013 08:11 AM
Does anyone have experience moving C3D projects to a new server, specifically regarding data shortcuts?
For example, current projects live in: \\server\share\xxx\proj_number\
Soon, that path will be \\A_new_server\\shareB\proj_number\design\
Upon internal inspection, the data shortcuts are storing the full path and a relative path. Based on our initial tests, C3D is resolving the path to the source drawing using the relative path, even though the "full path" stored in the data shortcut is invalid.
I don't think we will need to use the "Data ShortCuts Editor" to fix the paths as long as the relative directory structure remains intact.
If you have done this, comments welcome. Thanks!
Distinguished Mentor
michael.robertson
Message 2 of 7 (459 Views)
Re: Data Shortcuts and moving C3D projects to new server
01-22-2013 10:34 AM in reply to: rkmcswain
The relative paths will work fine as long as the old path no longer exists.
Just make sure the old path cannot be resolved or you are opening a BIG can of worms.
Not sure, but I would assume you would get a little perfomance boost if the full paths were fixed since it appears that is where C3D looks to first find the definition file.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
rkmcswain
Message 3 of 7 (454 Views)
01-22-2013 10:42 AM in reply to: michael.robertson
Yes, the old path all the way back to the server name, will not exist.  IOW, the project(s) will be on "A" one day and "B" the next (at which time "A" will go away).
Thanks!
Distinguished Contributor
nilesh33
Message 4 of 7 (404 Views)
01-28-2013 08:54 AM in reply to: rkmcswain
There is option of datashortcut editor under start>>autodesk>>
It is same like x-ref manager in autocad.
This works fine for me, hope we do same for you.
Nilesh J
Civil 3D 2012, SAC
16 GB Ram 64 Bit Win7
jmayo
Message 5 of 7 (393 Views)
01-28-2013 11:12 AM in reply to: rkmcswain
Wow glad to see thats working. I put a new server in here around August. I was very afraid to take those bold steps. I mapped the same path to the new server. Left all current and old projects in the old folder structure and began placing new projects in the new folder structure. Old files have no issue finding D'ref or x'refs. It is pretty cool to learn that the drefs resolve. You may still have xref issues if a user did not have relative path selected, no? This was another fear of mine. Users are pretty lax here at times with pathing and overlay vs attachment.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
rkmcswain
Message 6 of 7 (363 Views)
01-29-2013 06:25 AM in reply to: nilesh33
As I mentioned, I don't want to have to do that for hundreds of projects.
And as I discovered and Mike R. confirmed, it looks like we won't have to.
rkmcswain
Message 7 of 7 (362 Views)
01-29-2013 06:27 AM in reply to: jmayo
Ha... I've been preaching relative paths for years, knowing that someday it would become very important...
Well, that day is getting near and everyone is scrambling to get their projects fixed...
Actually, the majority of our referenced files are in the same directory as the parent, so it shouldn't be that bad anyway.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
