Hi All,
I'm having problems getting superelevation data to transfer to different drawings by means of an alignment data shortcut. I know alignments hold the superelevation data so I've gone into my alignments data shortcut, input my superelevation data, saved and closed. Now when I open my finished grade drawing, reference in my alignment and profiles, then create a corridor from that information, my superelevation didn't transfer with the reference. I pulled cross sections and it appears is has no clue there is any superelevation data. Also, I tried bringing it directly into the drawing I'm doing my corridors in and it errored saying I must be in the parent alignment drawing. Anyone have any ideas? Data shortcuts are pretty much useless to me if superelevation data doesn't transfer.
Kevin
64 bit Windows 7
Intel Xeon (R) @2.8GHz
6.00GB Ram
Civil 3D 2012
Solved by sboon. Go to Solution.
I've just tested this. I was able to create an alignment with superelevation, and then data reference it into a second drawing. I then checked that the superelevation parameters were available in the second file and added superelevation labels. I also created a simple corridor and confirmed that it is using the superelevation.
It's amazing what good a night of sleep and a fresh brain does. You were completely correct that the superelevation data transfered with the data shortcut. It was a problem with the assembly. Thank you for your help.
-Kevin
