An error dialogue box appears whenever we open drawings containing data shortcuts. (see attached image.) The projects effected are all new ones (running 2013), and didn't always have this error. We are not running from an XML file which makes things all the more curious. The error appears at start up, and there is one dialogue box for each data shortcut. Though is states that another file is open, we have tested it, and the error appears even when none of the project drawings are open.
The data shortcuts are still syncing and up to date, but we are stumped as to why this is happening.
Any help would be greatly appreciated!
Thanks!
Lindsay
There can be issues with special characters in the naming of Shortcuts. I'm only seeing a dash - in your path shown but I avoid using dashes, so not sure if that's the culprit. Underscores aren't a problem, it's the only special character I've used for shortcut names, IMO they are best avoided.
The shortcut path / name also has a character limit of 256 characters.
See this Being Civil post for more info.
