New Member
rogelio_castro_fierros
Message 11 of 20 (508 Views)
Re: Data Shortcut Error 2011.
09-01-2012 04:03 PM in reply to: mikeevans
Dude
 I had the same error... types SHORTCUTASSOCIATEDISABLE in command line and problem solved!!!!
mabbas
Message 12 of 20 (482 Views)
09-04-2012 01:40 PM in reply to: rogelio_castro_fierros
I am also having the same problem with the data shorcuts (Civil 3D 2013). I have tried the suggestions posted so far, but no luck. Any help would be appreciated.
Active Member
josh.bonora
Message 13 of 20 (422 Views)
11-28-2012 02:50 PM in reply to: mikeevans
I have the same problem using 2012 in that i would repeatedly get the error message requiring the dwg to be saved. I found that i couldnt create data shortcuts as my alignment was already linked to something in the dwg, In my case a profile & corridor. Once i deleted the corridor that it was linked to i could immediately create shortcuts.
Civil3DReminders.com
Message 14 of 20 (384 Views)
12-19-2012 11:24 PM in reply to: josh.bonora
It appears to have something to do with corridors and it's state when a save happens. Locking the layer the corridor is on appears to prevent the corridor from changing it's state based on the save action.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
New Member
bjohnson
Message 15 of 20 (366 Views)
12-28-2012 06:40 AM in reply to: mikeevans
I'd experienced this error using Civil3D 2013.  Previously my 'File Save' >> 'Save as:' Setting was set to AutoCAD 2010 (*.dwg).  Whoever suggested problems with backwards compatibility was right, in my case.  I changed this setting to AutoCAD 2013 (*.dwg) to match the year of the version I have and then I was able to create data shortcuts.  I hate to forfeit compatibility for this though.
4Runner
Message 16 of 20 (246 Views)
06-04-2013 09:43 AM in reply to: Civil3DReminders.com
I'm still having this issue with Civil 3d 2014... I tried locking all layers... I do my corridors in a completly seperate drawing just to avoid this... But it's still happening. Any other ideas/fixes? Thanks.
4Runner
Message 17 of 20 (243 Views)
06-04-2013 09:54 AM in reply to: Civil3DReminders.com
Nevermind. I eventually got it to work. No corridors in my drawing but I entered this command SHORTCUTASSOCIATEDISABLE, saved, restarted cad, locked all layers, and then I could create shotcuts.
New Member
brandyrodriguez
Message 18 of 20 (205 Views)
07-29-2013 07:23 AM in reply to: mikeevans
I was getting the same error, I would have to ask another coworker to open the design file and add it for me then close out. I ended up going to the options command and setting the save as default to 2013 instead of 2010 and I am able to add data shortcuts again.
john.mckenzie
Message 19 of 20 (192 Views)
07-30-2013 12:36 PM in reply to: brandyrodriguez
I have had this happen to me in the past where I KNOW I have saved but still cannot create the datareferences.
what I found as a solution is to make sure that I associate current project to dwg and then save. After I do that I have no issues. I suspect the "....associatedisable" setvar mentioned earlier circumvents the need to associate project to dwg and therefore accomplishes a similar result. Although the dwg will not necessarilly associate with the project if disabled.
New Member
mark.d.presley
Message 20 of 20 (26 Views)
06-04-2014 11:53 AM in reply to: hardin
had the same problem today... based on the info i did the following with success.  civil 3d 2013
close dwg
file
  drawing utility
     recover
select origin file for surface
right after the recovery process go to toolspace select surface and pick the data shortcut button from the ribbon
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
