silvernich
Message 1 of 3 (1,670 Views)
DWG coordinate system transformation
1670 Views, 2 Replies
11-20-2012 11:33 AM
Hello all,
My group is trying to convert a dwg from one coordinate system to another. The original drawing contains points, blocks, etc. in 1 system and we need it in a different one. We tried attaching the dwg to a new map with the new system using a layer query, but this did not appear to bring in the objects into the new system.
Any suggestions?
"Structures" is in the original system (OR83-NF), "StructuresHarn" is in the desired system (ORHP-NIF)
Thank you again.
P.S. C3D 2011
Civil 3D 2013, HF3.0
Windows 7, 64-bit, SP1
tcorey
Message 2 of 3 (1,662 Views)
Re: DWG coordinate system transformation
11-20-2012 11:50 AM in reply to: silvernich
To translate the points, export to an ascii file.
Start another drawing, set to the other coordinate system. Make a Point File Format that matches the exported file and be sure to assign the point file's coordinate system as part of the format. It's on the dialog, you'll see the option.
Import the points and be sure to check the box for Do coordinate transformation if possible.
For your linework, use the AutoCAD Map query function.
Civil 3D intelligent objects are not queried by AutoCAD Map. I wish that was not the case, but such is life.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Member
aslejo
Message 3 of 3 (1,635 Views)
11-20-2012 01:37 PM in reply to: silvernich
Use the ‘Locate using Geographic Data’ on the Attach External Reference. Create a new file an assign the new coordinate system, then xref the original file, but instead using the insertion point select the ‘Locate using Geographic Data’ at the lower left corner of the xref window. This should bring everything into the new coordinate system after that you can bind or insert the xref and explode it (only once).
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
