First time using the dwf publish in Civil 3d 2011. In LDD 2009 I could publish a DWF and selct any layout tab in any drawing and add that to my DWF. Now there are now options for that as far as I can see. Am I stuck with having to creatye a sheet set (which I might add thie interface isnt very intuitive) and plottign from that?
Solved by randcdavidson. Go to Solution.
Solved by AlmasSuljevic. Go to Solution.
Hi Westhills,
I am not exacly clear what you meant so please bear with me. If you were trying to publish to DWF through Sheet Set Manager (SSM), you still can select multiple sheets, right-click and choose Publish to DWF. Also using PUBLISH command from drawing will allow you to select multiple layouts to publish. Can you please clarify?
If I'm reading your problem correctly when you click the Civil3D ribbon (not sure the exact name the icon in the upper left corner of C3D). when you get the publish option don't go into the fly-outs just click on the publish and it should bring up the publish options box.
That is just what I was looking for. Thanks for the help. In previous versions sheetsets were independant of the publish process.
