Is there a way to add descriptions to DS project folders after the fact?
Joe Bouza
Solved by Jeff_M. Go to Solution.
Yes, but you will need to edit the "ShortcutsHistory.xml" file for the project.
Edit: I removed the description of how to do this because I now can't get the description to display. I know I've done this in the past, now to figure out why the method I used isn't working.
And the curse manifest itself upon the victim causing inexplicable misspelling
Jeff, thanks for looking
Joe Bouza
LOJ, Thsta funnnu
Joe Bouza
DarrenP
in case any one else wants to know what blog it is
DarrenP
It is a very nice blog, but I am either too dense or too stupid to understand it. I do not have a shortcuthistory.xml file in the places discussed. I'm thinking it should be on the server somewhere, how else would other read it?
Joe Bouza
Sure you do, Joe. It is not saved to the server becuase it is a per-user cache. In the address bar of Windows Explorer, type in %APPDATA% and hit enter, it will take you to YOUR profile's Appdata roaming folder, browse down to the folder shown. It should be noted that each version of C3D keeps it's own cache as well.
I searched our server for short*.xml and nothing came up?
Joe Bouza
I get it now - one ShortCutHistory.xml per project.
Its really quite simple once you understand it
Joe Bouza
