Civil 3D Forum
DS oddity
2 REPLIES 2
Joe-Bouza
201 Views, 2 Replies
DS oddity
I have a sheet drawing that that I copied from one project to another, and change the project association in the DS node of the prospector. Created new profile data and DS'd to the copied sheet. The prospector shows only the new alignments and profiles in the node.
Here is where things start getting weird: When I try to create a profile view the wizard shows the correct alignment, however the station range in the wizard shows 0+00 to 0+00? And if I just click create profile view it create an empty view 0+00 to 0+00 with an alignment name from the old project!?
There is nothing in the prospector from the old project and as I sai I associated the drawing with the new project.
Anyone see this before or know a way out?
Joe Bouza
2 REPLIES 2
troma
in reply to: Joe-Bouza
What happens if you manually type in the required stations?
Mark Green
Working on Civil 3D in Canada
Joe-Bouza
in reply to: troma
t,
I'll get back to you I am needed in the field.
Joe Bouza
Rail Community
