We are considering going to a system like dropbox which uses "cloud" technology. We have a few people that work from different places and we are looking at this as an alternative to have a server. Has anyone used this? Are the=ir any issues with vault, or ldd projects or xref files? Any input on this would be greatly;y appreciated.
Hi
I have been using dropbox for a couple of years now to keep my custom Autocad code and settings between my work pc and home laptop
in sync. I just have everything in a common folder and have that copied upto dropbox.
There is one issue in that the local dropbox folder can not sit on a network drive(this may of been updated) so you have to use synctoy or something similar to sync between the local dropbox folder and the network folder.
I decided to use drop box after looking at other cloud products as it supports a lot more file formats. and dwgs work with out zipping them.
have not looked into doing xrefs with in the dropbox folder but single dwg files are fine.
Regards
Justin Ralston
I use Dropbox to sync files between the home, laptop, office, and remote office...
I've even opened drawings off the drop box and shared them among collegues...
I would be concerned with the sync if you are sharing and working on similiar files...
