I converted to C3D 2013. Then I opened my C3D 2012 drawing in the C3D 2013 but the Drawing and Coordinate axes, on one hand, and View ViewCube, on the other, were out of orientation to each other. I attached a capture herewith.
Any solution to this problem will be appreciated.
Solved by Jeff_M. Go to Solution.
Your UCS could be aligned with your view and not with world. Type "UCS" and ten type "W" for world. You may need to reset your viewpoint as well, if your view was rotated. Good Luck!
