I am using Civil 3D 2013.
I am trying to drape an image over a surface. The workflow I used is a s follows: I selected the sureface, on contectual tab selected Drape Image, and selected the image. When I did an orbit, the image was still set below the surface, not draped at all. What steps am I missing?
Solved by Alfred.NESWADBA. Go to Solution.
you can freeze the layer onto which the image is inserted (referenced). Civil creates a material that uses the image as texturemapping and when you use _ORBIT you should set the visual style to "realistic" and you should set the triangles to visible in the surface-style to see the material visualized on top of the surface.
- alfred -
