Civil 3D Forum
DRAPE IMAGE
1 REPLY 1
CADEngr2014
797 Views, 1 Reply
DRAPE IMAGE
I am using Civil 3D 2013.
I am trying to drape an image over a surface.  The workflow I used is a s follows:  I selected the sureface, on contectual tab selected Drape Image, and selected the image.  When I did an orbit, the image was still set below the surface, not draped at all.  What steps am I missing?
1 REPLY 1
you can freeze the layer onto which the image is inserted (referenced). Civil creates a material that uses the image as texturemapping and when you use _ORBIT you should set the visual style to "realistic" and you should set the triangles to visible in the surface-style to see the material visualized on top of the surface.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Rail Community
