I have a DEM file, (or that is what I have been led to believe) it is in space delimited txt format. It contains breakline and point data. Every time I try and add it to a surface I get an invalid DEM file error. Can anyone give me a hint as to why and how I can correct this. I am using Civil 3D 2013.
Solved by ToddRogers-WPM. Go to Solution.
A lot of the entities out there have changed there file format for there DEM's and they don't work in Civil 3D anymore. TNRIS is one of these entities. I use Global Mapper to fix the file and export it back out as a DEM. If it's not too large, you can email it to trogers@tcadsys.com and I will fix it for you.
Ok. I didn't read this very well the first go round, and apologies for that. You need to import this as points, not attach it to surface as a DEM. It looks like the point file format is PENZD. Then add the Point Group _All points to the surface. Works fine.
@Anonymous wrote:Ok. I didn't read this very well the first go round, and apologies for that. You need to import this as points, not attach it to surface as a DEM. It looks like the point file format is PENZD. Then add the Point Group _All points to the surface. Works fine.
If the file is very large, dont' import it into Civil 3D as points, just add it directly to the surface as a point file. Works much better that way for very large data sets.
Obviously, since Todd recommended importing it as a points and then using adding it to the surface as a point group, this particular file probably isn't very large, but it's good for others to know about if they didn't already.
Is it just me or do I sound like I'm babbling?
You're not babbling. 🙂
I just see you providing an important public service announcment. That is a very important tip for large data sets.
John Mayo
Thanks for the help, evertyhing is working great. I made that a lot harder than it seemed.
What did you do to get the data into the surface? Import points? Point group? Add point file? Enquiring minds want to know.
It was a rather small file, so just a basic import of the points using PENZD did the trick. The file had an extension of points.dem.txt. So it was really just an ASCII file, not a DEM file.
I gave you props on my blog about the double click addition
http://civil3dj.wordpress.com/
