I used two DEMs for a surface model but need to change the folder name where they are stored. If I change the name the surface no longer finds the DEMs. Is there a way to change that path?
Solved by peterfunkautodesk. Go to Solution.
Yes, got into "Surface Properties" and then to the "Definition". You should see a "Create Grid from DEM File" operation. To the right is a folder that you can pick and repath to the new location (or to a new file).
Cheers,
Peter Funk
Autodesk, Inc.
Thanks, Peter. I thought it could be done using the DEM properties in the Prospector preview but the path is locked.
