I need to figure out the amount of cut and fill up to a specific elevation, the Base Flood Elevation. Right now, I am creating the proposed and existing surfaces in Civil 3D and making a fellow coworker convert it to Eagle Point to generate this slice Volume Table. See attached PDF. Is there a way to generate this type of table in Civil 3D? Any ideas? Thank you!
Is this what you're looking for?...
This can be exported out to a TXT file.
Another option is to set a user contour to your required elevation. Extract the contour as a polyline and use it/them as a boundary. Even if the boundary is only temporary.
You may have to edit them a bit to get the desired results.
Conan Witzel
Yes but how do I compare the existing and proposed surfaces? It only allows me to select one of the surfaces. Thank you for your help!
I am trying to do a volume comparison between the proposed and existing surfaces and have to show the cut/fill volumes in one foot increments.
