Civil 3D Forum
Cut and fill Are colculation using Quatity Takeoff Report
3 REPLIES 3
149 Views, 3 Replies
I still have a problem with area colculation using Quantity Takeoff report,
hi colculate the section areas, but I need the plan area 2D area like in
picture the area of black contours and the red contour in each ten meters,
the black contour mean fill the red contour means cut
Darius
3 REPLIES 3
You need to generate a Volume Surface. Go to Surfaces in Prospector,
right-click and make a new one. Instead of a TIN, select Volume Tin, then
your two comparison surfaces. This new surface will let you apply the schema
you're after as a style.
HTH
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006/SP2
www.jones-boyd.com
www.ee2inc.com
The schema I generate, but I need the areas of each contuor color in 2d
like the red countor area from 1+00 to 1+10 is ...
"James Wedding" wrote in message
news:5053760@discussion.autodesk.com...
HTH
James Wedding, P.E.
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
www.jones-boyd.com
www.ee2inc.com
So you need the area of each contour?
I hesitate to say this, but put an UNDO MARK in your drawing, then explode
the surface. When you have all the data you need, UNDO BACK to the
preexploded state.
Does that do it?
James Wedding, P.E.
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
www.jones-boyd.com
www.ee2inc.com
Rail Community
