Civil 3D Forum
Cut & Fill valume in Diferent Hatch patterns
3 REPLIES 3
Askarali
532 Views, 3 Replies
I want  to show Cut & Fill valume in Diferent Hatch patterns (Excluding Solid Hatch).
Askarali Mulla
3 REPLIES 3
mathewkol
in reply to: Askarali
You need to ensure you have chosen an appropriate criteria when setting up your material volumes. One that uses different styles for cut and fill. The out of the box "Cut and Fill" criteria is such an animal.
Then it's simply a matter of editing the shape styles accordingly.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Askarali
Hi All,
I have two surfaces i.e., Existing Surface and Earth work Surface. I create COMBINED surface (Cut & Fill area). Now It is shown Cut and Fill area. I have changed surface styles like Tringulation, Contours and Elevations.
In Elevation style I chose the "Number of Ranges" option and I select the 2 ranges i.e., Red Colour is Fill area and Blue Colour is Cut. Then, in Analysis option I chose the "Display Style" as "3D Hatch". So it is shown Solid hatch.
BUT, my requirement is Other than Solid hatch like Zig Zag, Rectangle, Brick, Sand etc.,
Please guide me the prosses STEP wise.
Askarali Mulla
neilyj666
Not sure that you can have anything but SOLID for this kind of thing
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
