Civil 3D Forum
Cut & Fill hatching
8 REPLIES 8
Message 1 of 9
cceleeds
2805 Views, 8 Replies
Cut & Fill hatching
Afternoon
Is it possible to change the cut and fill pattern from solid bands of colour to bands of colour cross hatch (for example)? The reason for this is, when printing the drawing uses a lot of ink.
Thanks in advance
8 REPLIES 8
Message 2 of 9
jmayo-EE
in reply to: cceleeds
Hopefully someone will have a better solution than extracting 2d triangles from the Cut/fill elevation analysis, using QSelect to grap the cut triangles, running linewrokshrinkwrap, hatching the border and repeating for the fill.
Another option is to setup a Plot Style Table that will screen two pens you could use for cut/fill. See the attached screen cap.
John Mayo
Message 3 of 9
neilyj666
in reply to: jmayo-EE
If using 2012, what about using transparency on the surface object, if using 2013 don't bother as they broke this functionality.....!!!!
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 9
C3D_TomR
I envision a workflow where you extract a user defined contour of elevation 0 from your cut/fill volume surface and use that as a boundary for creating your crosshatch boundaries. Of course it won't update automatically but you can extract the new boundaries and set the hatch to use the revised boundaries without too much difficulty.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 5 of 9
C3D_TomR
in reply to: neilyj666
Good suggestion. Just don't forget to enable "Plot Transparency" when plotting.
Tom Richardson
Twitter | LinkedIn
Message 6 of 9
cceleeds
I am new to Civils 3D, what do i exactly need to change in the transparency commands?
Ian
Message 7 of 9
neilyj666
Try this blog post http://bimontherocks.typepad.com/my_weblog/2010/04/civil-3d-2011-using-autocad-2011-layer-transparen...
......but bear in mind it doesn't work in 2013 and use C3D_TomR's advice to set transparency in the Plot options (not in 2013 obviously)
Message 8 of 9
cceleeds
That does work great in 2012, unfortunately we work in 2013.
Do you knolw if Autodesk will be bringing a fix out for the transparency issue?
Ian
Message 9 of 9
neilyj666
If I knew (which I don't) I couldn't tell you..Smiley Sad
It's a reported bug which I had hoped would have been fixed by now but still waiting.......perhaps in 2014Smiley Frustrated
Rail Community
