Hi Ted,
Do you have any holes in your tin's? Import the contours and boundaries for
the volume surface and see if it has any anomalies in it.
Anyway, when I come up with numbers that are off, nine out of ten times it's
because a spike or a hole or some sort of a glitch in the surfaces that I
didn't notice before running the numbers.
I do a lot of volume calcs in C3D and LDDT, and I'm not aware of a setting
that's goofed up my numbers yet, it's been the operator (my) error every
time. As much as I hate to admit it.
[It's unfathomable, I know what I'm doing!!! Who? Me? Make a mistake?
Neverrrrrr, my ego doesn't allow mistakes? I'm infallible, just ask me! -
LOL]
In the interest of quality control, the first time I run a volume calc, I
always run it as a volume surface (as opposed to going to
surface>utilities>volume... ), so I have a chance to inspect it, and
convince myself that I'm getting a believable number.
Volumes calcs are rather picky about holes and spikes in the tin. Applying
surface boundary (outer/show/hide) has an effect of creating a hole in the
surface, as far as the volume calculation is concerned. Masking doesn't
appear to affect the volume calc, but it seems to give the visual effect
only.
Did you and your coworker work off the same comparison surfaces, or did you
each create your own? This one seems to be a less likely scenario, but, did
you check your units?
wrote in message news:5264676@discussion.autodesk.com...
I have read the previous topics with the same main idea but I need someone
to help me understand something.
I know how to generate cut-fill volumes, but I was suspicious of my findings
so I had someone redo the numbers by hand. My number for cut was only 14,250
cubic meters and my co-worker's number was 30,000 cubic meters.
To make a long story short - I trust his figure because I broke up my entire
surface (700'x700') into areas (4: 200'x700' & 2: 65'x700') and when I added
all the separate areas I was close to his number.
Is there a setting in Civil 3D that I missed to tell the computer to tighten
up the calculations, or something?
Thanks.
Ted
