Civil 3D Forum
Cut Fill Labels on Volume surface
7 REPLIES 7
Message 1 of 8
3485 Views, 7 Replies
I have a problem, I need write Cut and Fill Labels on Volume surface in each
10x10 meters. Civil 3D can write Spot Levels on grid, but I need write Cut
and Fill values in grid area. Using Surface >Utilities>Bounded volumes I can
get the values on selected closed polygon, but write to all is very long
work.
Maybe someone have an idea how to do write Cut and Fill labels on grid.
Regards
Darius
7 REPLIES 7
Message 2 of 8
Try this:
http://civilcommunity.autodesk.com/blogs/blog/5/blogpost/2945/
Google is your friend.
Bill
"Darius" wrote in message
news:6203239@discussion.autodesk.com...
work.
Regards
Darius
Message 3 of 8
Thanks Bill,
It is a good thing. Maybe I not write what exactly I need. I must write
Labels like on this example, but I need Cut volume and Fill volume of grid
(10x10).
Darius
"wfb" wrote in message
news:6203247@discussion.autodesk.com...
Try this:
Bill
work.
Regards
Darius
Message 4 of 8
Darius:
You are correct. You asked for Cut /Fill Labels. Now you want Cut / Fill
Volume labels.
Sorry on my part. Seems like some sort or overkill. Perhaps you can take
the C/F labels ( @ center if ea. square) and with an expression multiply by
area.
Bill
news:6203244@discussion.autodesk.com...
Thanks Bill,
(10x10).
Darius
Try this:
Bill
work.
Regards
Darius
Message 5 of 8
Matt.Anderson
Darius -
That isn't an easy task - but it can be done.
The Civil Community site has a tool written by Nick Zeeben regarding calculating multiple Parcel volumes. It doesn't sort, but the output is generated.
With a little hack, one could export that to a CSV file and link it back to an excel spreadsheet.
Not 100% dynamic, but it does work.
Matthew Anderson, PE
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 6 of 8
hi bill, i cant access that link. can you explain. the process of cut and fill per square area. thank you.
Message 7 of 8
troma
Are you looking to label the depth of cut/fill, or the volume?
Mark Green
Working on Civil 3D in Canada
Message 8 of 8
Krite1
Try the cartogramma extension from the subscription site this should do what you want.
Rail Community
