Civil 3D Forum
Custom line won't scale anymore...
6 REPLIES 6
Rubixcube10
483 Views, 6 Replies
a few weeks ago my custom line would scale right.  Now it just doesn't do anything.  The words in my custom lines alway stay small no matter what scale I change it to.
Rob
HP Compaq 8100 Elite
Win 7 Pro SP1 - 64Bit
8GB RAM
i7 860 @ 2.80 GHZ
AutoCad Civil 3d 2012 SP1
6 REPLIES 6
wfberry
in reply to: Rubixcube10
What about you blocking out the line and post it.
Bill
Rubixcube10
I draw the line at 1"=1', and it still looks like this no matter what scale I change it to afterwards.  Even in paper space it doesn't work right.  My tree line works fine but custom line with words in it just stays the same.  Very tiny.  thoughts?  Are these pictures what you were looking for?
Rob
8GB RAM
i7 860 @ 2.80 GHZ
AllenJessup
Was the text style used in the linetype redefined to have a constant height?
Allen
Allen Jessup
CAD Manager - Designer
Rubixcube10
in reply to: AllenJessup
I'm guessing it was set at a constant height.  It was a annotative text.  When I first created the line I used the annotative text.  then when it was all done and made a new line using the custom line next to the original to compare, only my original text would change.  The custom line wouldn't.
Even the normal fence wires from the aeccland.file does the same thing.
Rob
8GB RAM
i7 860 @ 2.80 GHZ
thepworth
check the style of text you're using in the linetype.  if someone has modified the text styles in your template to redefine/modify the embedded text font in the linetype definition, then things can go haywire.
Rubixcube10
in reply to: thepworth
Yep, you're right.  Thanks.  I turned off the annotative.  Tried it again.  Still did the same thing.  Then changed the auto text height to the approriate scale I want and it worked.  Thanks again to both of you guys.
Rob
8GB RAM
i7 860 @ 2.80 GHZ
Rail Community
