Hello All,
I am trying to create an elevation label that will give me the spot elevation followed by the letters "TC" and then on the line below subtract 4 inches from the elevation followed by the letters "BC". It's easy enogh to add the letters but the simple equation of elevation - 4 inches eludes me.
Thank you for your help.
Solved by rl_jackson. Go to Solution.
You'll need to create an Expression, and then add that to you label style.
Rick Jackson
Survey CAD Technician VI
RL's got it right. create an expression with your formula, give it a name that makes sense, then reference the name in your label style
Oh... my... God. This is... AWESOME!!!
Also, another example of how you can find the answer you need by searching and without starting a new thread and asking a redundant question.
