I am creating a custom profile view to change the scale and exaggeration. The numbers come up with a precission of two places after the decimal. I want to change this to whole numbers with a precision of 0. Where can I find this option? I cannot seem to find it under the Profile View edit command.
Solved by doni49. Go to Solution.
WHICH numbers? If you mean the numbers shown on the profile, then you need to look at the label settings of your Profile View Style.
Don Ireland
Engineering Design Technician
I looked under my active Station/Elevation label style and there is no place to set precision.
Don Ireland
Don-
I found precision command and set to 1 and apply. The precision keeps reverting to 0.12 for some unknown reason.
Thanks for showing me how to find it. Now if I can only get it to work.
Make sure not to forget that arrow (step 4) from my screen shot.
I used to forget that all the time -- still do sometimes.
Don Ireland
Went through the editor on the Edit Profile View Style and it worked.
I'm glad to hear that you got it resolved.
Don Ireland
