Civil 3D Forum
Curved Ramps
10 REPLIES 10
Message 1 of 11
marcoarmstrong7258
1501 Views, 10 Replies
Curved Ramps
How do you merge a ramp on to the main highway using corridors? Also how would you make that surface with two different alignments? I have my main road alignment and a ramp that comes on to it so the problem I'm having is making my 3d model with the road and surface combine.
10 REPLIES 10
Message 2 of 11
Under Intersections, select Add Approach.
Todd Rogers
Message 3 of 11
sboon
in reply to: ToddRogers-WPM
Todd, I'm not sure that this solution will work for the OP.  Could you provide more details?
Steve
Expert Elite Alumnus
Message 4 of 11
ToddRogers-WPM
in reply to: sboon
Yeah, i totally misread that.  Most likely going to have to manipulate the corridor with targets.
Todd Rogers
Message 5 of 11
sboon
Marco, I did a class on this topic at AU2012.  If you have access to the class materials then search for my session.  It details a workflow which should work for your situation.
CI2160 - Intersections from the Inside Out.
Steve
Message 6 of 11
marcoarmstrong7258
in reply to: sboon
How do I get to the class sessions
Message 7 of 11
marcoarmstrong7258
in reply to: sboon
I'm sorry I meant the class materials
Message 8 of 11
Go to this link and look for the classes: http://au.autodesk.com/?nd=classes
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 9 of 11
Another easy job for the Intersection Wizard.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 10 of 11
If you are planning to start a new project and have similar situation you can create one long corridor with multiple baselines and multiple targets. This is good approach but I would advise it to seasoned users since there is very easy to get lost in the design. If you have two separate corridors next to each other, (It seems that it is the case here) there is no way to merge them.
Almas Suljevic
Autodesk, Inc.
Message 11 of 11
I just did the real quick with the Intersection Wizard, but hopefully it gives you the idea. This is one corridor with two alignments.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
