I have an alignment that is line and curve tagged for a table. The last segment of the alignment is a 3 point curve. It shows up in the alignment grid view, and is tagged. When the table is produced the everthing comes in except the 3 point curve I mentioned. Any ideas?
Try the Add Items tool from the ribbon when you select the table, use the select from Pick On-Screen button in the bottom left to select the reluctant label. That should add it to your existing table.
