Civil 3D Forum
Curve labels skipping number
3 REPLIES 3
smithdl85
970 Views, 3 Replies
I am adding curve label numbers to a parking lot to create a table with the curve delta/radius. My problem is that #9 is being skipped. Its going right from 8 to 10. Any help?
3 REPLIES 3
csevers
in reply to: smithdl85
I have the same problem but mine is skipping, from 6 to 9.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
IanMcClain
I had a similar problem and the following worked for me:
-Set the next tag number to the missing number.
-Create the tag and when prompted choose to create a duplicate number.
I made a table using all tags in the drawing, expecting there to be a duplicate number, but there was not. I never found the duplicate tag.
Ian McClain
csevers
in reply to: IanMcClain
Yes, I found that same solution
This e-mail and any attachments contain URS Corporation confidential information that may be proprietary or privileged. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies.
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Rail Community
