Has anyone else had curve tables which after selecting the curve tags in Sequential order (C1, C2, C3, etc) the table is created but the order of the curves does not run sequential. I have a table with 22 curves - the order is fine thru C10 then jumps to C21, C22, then down to C13.
Is there a way of arranging the curve numbers? The information for all the curves is correct. It is just not easy to look up the curves when they are not in order.
See the attached image.
Cliff Patterson
Rocke & Associates
Fort Wayne, IN.
Civil 3d 2007, SP-3
Xeon 2.80 Ghz, 2.0 GB Ram
