My curve labels keep skipping. Why do they keep skipping from C6 to C9? I know how to use the renumber tags command. It just keeps skipping C7 and C8 for no apparent reason. There are no tags on frozen or off layers. When I add all possible objects to my curve table it does not change.
The problem I have here is that the curves are numbered by the order the PIHs are created and not by the alignment station sequence...
If I have ten curves in an alignment and then add a new PIH in the middle of it, this one will be the last numbered, not following the alignment sequence. The only way I could fix it was numbering the curves one by one...
