Valued Contributor
Umit.Arslan
Message 1 of 3 (230 Views)
Curve+Curve+Spiral
230 Views, 2 Replies
02-03-2014 12:37 AM
Hi
How can i add a "curve+curve+spiral" to the PI point "S1"?
- Umit Arslan -
Survey Engineer
Civil 3D 2014 x64
Windows 7 64-bit
16GB RAM
Valued Mentor
ericcollins6932
Message 2 of 3 (191 Views)
Re: Curve+Curve+Spiral
02-03-2014 06:45 AM in reply to: Umit.Arslan
I would break up the alignment so I could use adding curves from end of entity (starting at S1) and go from there. Others might have better suggestions.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
sboon
Message 3 of 3 (170 Views)
02-03-2014 08:58 PM in reply to: ericcollins6932
Start by breaking apart the PI, then you can add the pieces you need to connect the tangents.  It depends on what parts of the curve-curve-spiral are constrained and which are not.  I've attached a drawing with several possible combinations.
  • The first alignment has a floating curve with a specified radius attached to the incoming tangent, a second floating curve attached to that and a free spiral connecting to the outgoing tangent.
  • The second alignment has a floating curve-spiral with specified radius and spiral length attached to the outgoing tangent and then a free curve between that and the incoming tangent.
  • The third alignment has a curve with fixed centerpoint and radius in the middle, then a free curve connecting from the incoming tangent to it, and a free spiral connecting to the outgoing tangent.
There are probably more possibilities - choose the elements that work for your situation.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
