AutoCAD Civil 3D General
Member
Message 1 of 5 (246 Views)
Accepted Solution
Curb drop in corridor
246 Views, 4 Replies
01-09-2013 01:03 PM
I have a corridor with multipule intersections. I modeled the primary road straight through the intersections. Created ETW alignments and profiles to target in the intersections. Most intersections did not require this but one complex one did. All other quadrents in this intersection worked out except for this one (see attached). In this intersection the primary road alignment leaves the centerline of the road and transitions to a lane. I can't seem to figure out what this one quadrant is trying to target?
*Expert Elite*
sboon
Message 2 of 5 (213 Views)
Re: Curb drop in corridor
01-10-2013 12:12 AM in reply to: twagner21
It looks right horizontally but the elevations look wrong.  Is it possible that the target profile doesn't exist at this station range?  Can you post the drawing?
*Expert Elite*
Joe-Bouza
Message 3 of 5 (205 Views)
01-10-2013 04:56 AM in reply to: twagner21
I have had fairly good success making the returns as there own corridor and target the ETW Feature line; no need for the extra alignment profile overhead. Then make a Final surface FG with pasted corridor surfaces.
Then If I ever get the intersection wizrard down ....
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Member
Message 4 of 5 (199 Views)
01-10-2013 05:40 AM in reply to: twagner21
The target profile has to exist because the primary road and fillets are targetting the same alignment. I have no problem using the wizard. It seems a lot of people don't like it though. I use null regions for everything except my fillets. I had to target the ETW for the primary road in this intersection also because of the baseline transition. So if the primary road and fillets are targetting the same thing why would there be this drop. This makes me think its something with the assembly. But the other 3 quads worked out fine?!
I will see about posting the dwg.
Thanks!
Member
Message 5 of 5 (191 Views)
01-10-2013 06:54 AM in reply to: twagner21
Ok I figured it out...finally! Somewhere along the way when trying to solve other problems I must have changed the slope parameters for that edge profile. I just needed to change the lane slope back to the ETW profile in the intersection properties.
Thanks!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
