I have a corridor with multipule intersections. I modeled the primary road straight through the intersections. Created ETW alignments and profiles to target in the intersections. Most intersections did not require this but one complex one did. All other quadrents in this intersection worked out except for this one (see attached). In this intersection the primary road alignment leaves the centerline of the road and transitions to a lane. I can't seem to figure out what this one quadrant is trying to target?
Solved by twagner21. Go to Solution.
It looks right horizontally but the elevations look wrong. Is it possible that the target profile doesn't exist at this station range? Can you post the drawing?
I have had fairly good success making the returns as there own corridor and target the ETW Feature line; no need for the extra alignment profile overhead. Then make a Final surface FG with pasted corridor surfaces.
Then If I ever get the intersection wizrard down ....
The target profile has to exist because the primary road and fillets are targetting the same alignment. I have no problem using the wizard. It seems a lot of people don't like it though. I use null regions for everything except my fillets. I had to target the ETW for the primary road in this intersection also because of the baseline transition. So if the primary road and fillets are targetting the same thing why would there be this drop. This makes me think its something with the assembly. But the other 3 quads worked out fine?!
I will see about posting the dwg.
Thanks!
Ok I figured it out...finally! Somewhere along the way when trying to solve other problems I must have changed the slope parameters for that edge profile. I just needed to change the lane slope back to the ETW profile in the intersection properties.
Thanks!
