Personally, I've only had to do two cul-de-sacs - both had a single crossfall. Because of circumstances, I did each a different way.
The first I did basically as you describe, except that I stopped the CL baseline at the start of the bulb and ran the entire bulb of the EOB/LOK alignment, kerb and daylights on the left, LaneToCrown on the right with a target to the CL elevation. It took some fiddling to make it right, but the result was good (the final design is almost identical to what they constructed - call the media!). I found that while the profile "trace" for the EOB was a good start, the biggest help in getting the design right was the dynamic contours, which helped me identify where in plan the high point was and where had to be raised/lowered.
The second was a bit different, both in design parameters and modelling technique, but in that instance it was the kerbs that were the critical factor, so having designed the kerbs to a minimum, I ran the centreline through, checked how it targeted and adjusted it from there. Again, the contours were a big help in visualising what I was getting rather than what I thought I was getting. I came back and plugged an asymmetrical island in the middle of that one too - looked good.
I don't know how that helps you, but I hope it assists you some.
Trevor
