Member
richard.porter
Message 1 of 4 (168 Views)
Crown Feature Line missing OverlayMillandLevel2
168 Views, 3 Replies
11-20-2012 12:11 PM
I am having trouble with the Crown Feature line not displaying for the full length of my Corridor.
I am running the OverlayMillandLevel2 subassembly using the minimum clearance setting. I then want to extract the corridor crown line profile, but because there are sections missing I can not extract the entire crown line in one length.
I also have the problem of the crown feature line 'cutting' the corner, alongside the correct crown feature line.
The attached image shows the problems I am having.
Has anybody experienced this before? or know what the issue or fix might be?
sboon
Message 2 of 4 (156 Views)
Re: Crown Feature Line missing OverlayMillandLevel2
11-20-2012 12:54 PM in reply to: richard.porter
The feature lines in your corridor look similar to a bug that I have reported previously.  Are you running with SP 2.1?  See this thread for more details.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-Service-Pack-2-1-HEADS-UP/m-p/3603270/highli...
Member
richard.porter
Message 3 of 4 (139 Views)
11-20-2012 06:30 PM in reply to: sboon
I have run the design through 2012 w/ SP2.1 and 2013 w/ HF2.1 and still come up with the same issues. All of our current design is being carried out in 2013.
The HF did stop the feature line 'cutting' corners, but there are still the gaps in the feature line running along the corridor.
Do you still encounter the same bug with feature lines?
sboon
Message 4 of 4 (121 Views)
11-20-2012 11:44 PM in reply to: richard.porter
Yes, I first noticed it in the original 2013 release.  It appeared in 2012 after the installation of SP 2.1
Interesting that it seems to have been fixed in one version but perhaps not the other.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
