I have built a alingment, corridor, and surface of a driveway but I have a few holes in my surface. I tried to add lines to my TIN surface and some filled in properly but others would not and I had TIN lines that crossed (actually they are 4 different lines that meet at on point). Why does this happen and how can I fix it?
welcome @forums.autodesk.com !
What version of Civil3D do you have and do you have installed the latest servicepack?
What happens if you export the surface to LandXML and reimport it into a new drawing?
- alfred -
We figured out the issue I had not set a corridor border and I had deleted a line that was used within the surface when I was cleaning up the extra daylighting lines. I ressolved the issue by using a corridor border. Thanks for the help though
