How would I go about creating a cross-section band style in C3D 2012 like the one attached?
Thanks, Patrick
For starters I would think that using the proper template file(.dwt) to start your drawing. If this seem foreign, then I highly recommend you run through the installed Tutorials for Civil 3D.
Bill
Hi Bill, that isnt really my question. We have a good template already, but how do you get a band style to label specific parts of a corridor in the cross-section in a band as opposed to a label directly on the section?
We do not do anything similar in my locale.
Looking at your example reminds me of Australia or NZ which I thought AutoDESK had country kits for those. If not, you need to compose your own Band type Style(s). A little training may be in order.
Hopefully someone will hop in here with better info.
Bill
Thanks Jeff, looks about what i want - any tips on what the band settings are?
Create a band style set to display only grade breaks and borders. Get this to look how you want, then copy it 3 times. Edit each one to display the desired data for the grade breaks.
For the datum, I used the left axis title for the section view, not a band.
I can send the drawing I created these in if you want. It is one of the Section tutorial drawings (2012). Shoot me a Private Message with email address if so.
Start your new drawing using Metric setup. Insert Jeff's drawing using _INSERT command or drag-n-drop it onto the drawing window. The geometry needs to be scaled, but all his styles are there for your use.
