I have some cross sections showing existing and finished grade. The finished grade is a channel and floodplain with slopes to catch existing ground. I’d like to create a report of the offset and elevation at each grade break for the finished grade. Optionally, it could be offset and cut or fill at each grade break. I’ve found the tool to create annotation for the offset and elevation info, but the cross sections are too small on the drawings to accommodate all that text. Is there a way to generate a report for the section view group or even each section view that would contain that information?
If the channel was created from a corridor then you may be able to use one of the reports in the Toolbox tab of the Toolspace dialog. Expand the Corridors group and try the Feature Line or the Section Points report.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
