I'm new to this site, hopefully I'm doing this right. Here goes...
I'm using AutoCAD Civil 3D Land Desktop Companion 2009. When using the "Section Plot" > "All" menu, all my cross sections line up to the left in one column. Is there any way for them to line up from the center? That way when looking up the column, the centerline and stationings are in a row.
Thank you,
Linda
Solved by Joe-Bouza. Go to Solution.
Sorry Linda you are at the wrong DG you want http://forums.autodesk.com/t5/AutoCAD-Land-Desktop/bd-p/83
Joe Bouza
Please select "accept solution" so other readers may be aware of your solution......I can use all the point I can get
Joe Bouza
