Sheet Set Manager? Perfect case for it...
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
wrote in message news:5366154@discussion.autodesk.com...
Let me try to explain this a little futher. I have a base file "Grading
Base" with all my sections and point table views, which is currently
orientated with North pointing up. When I Xref the "Grading Base", I have
to rotate the view in order to get the disired display at a specified scale.
I would like to rotate the view of "grading base" file directly so I do not
have to keep rotating it every time I Xref it! But, when you rotate the
view of the base file, the sections will rotate as well. The point tables,
however, will not rotate because the tables maintain the view orientation.
P.S. When I mention rotate, I'm refering to the view only!!
