Civil 3D Forum
Cross Section Bands Query
3 REPLIES 3
neilyj666
586 Views, 3 Replies
Do Cross section bands follow the  same logic as Profile Bands??
I am using an OOTB style from the UKIE kit where editing the band style selects all three "bands".
I'm aimimg to get similar information (prof bands.jpg) as I can in Profiles but using Cross sections - is this possible??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
neilyj666
in reply to: neilyj666
No takers for this??
I'm getting a bit annoyed with these cross sections now.. may have to revert to using profiles instead...!!!!
Yes, Cross Section View Bands work along the same lines as Profile View Bands.
I think the three labels in one band was a solution to over come issues with jogged bands not looking right, but you can achieve the exact same look with three bands, each with their own information displayed, rather than one with all the info and two empty ones.
The trick is to set the jog height for the top band at say 3mm and the jog height for the rest of the bands at 0mm.
Section bands have a more limited range of label expressions to choose from but you should be able to achieve the same effect with what is available.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Thanks Andrew - I will look further into this now knowing that it can be done...Smiley Happy
Rail Community
