Is it possible to have XS sampled assemblies displayed on individual cross sections? I know that the sample line group properties control which assemblies are sampled and displayed. Say that assemblies A,B and C are sampled and displayed on sectiions from 0+00 to 3+00. Can ONLY assemblies A and B be displayed on sections from 1+50 to 2+00, and A.B and C on everything else?
Solved by Jay_B. Go to Solution.
@civman_daar wrote:Is it possible to have XS sampled assemblies displayed on individual cross sections? I know that the sample line group properties control which assemblies are sampled and displayed. Say that assemblies A,B and C are sampled and displayed on sections from 0+00 to 3+00. Can ONLY assemblies A and B be displayed on sections from 1+50 to 2+00, and A.B and C on everything else?
I'm not sure I understand the question but if you mean "Corridors" A, B, and C are all sampled and then can any combination of these be toggled on/off within the Section Views then the answer is yes.
Select a Section View>Rt Click>Section View Properties>Sections Tab>check/uncheck sampled sources as desired.
This can only be done individually one section view at a time AFAIK.
