I am trying to create a localized existing surface from a very large topo. I promoted the existing surface shortcut into my drawing, then created a cropped surface to be put in a new drawing. After creating the cropped surface the new file shows that a surface has been created, however, the surface contains no data. Any ideas whats going on?? I am using c3d 2012.
Solved by Okkin94. Go to Solution.
Figured it out myself - had to change the UCS back to "world" before it would work - just in case anyone else is wondering.
