Member
t2lv
Message 1 of 15 (1,084 Views)
Creating points at a specific number
1084 Views, 14 Replies
04-19-2012 10:20 AM
I am trying to set several hundred points along polyline verticies with the point number starting at 5000. There are no other points in my drawing, yet everytime I start the process, it begins at 1. I have set 5000 at my Next Point Number under Point Identity in the Create Points toolbar. I have also verified that the 'Save Command Settings" is set to yes under the 'Commands-Create Points'. We cannot get this to behave as desired.
Can anyone tell me what I'm missing? This is a 2D polyline with no elevations.
Civil3D 2013 64 bit.
TRogers
Message 2 of 15 (1,072 Views)
Re: Creating points at a specific number
04-19-2012 11:05 AM in reply to: t2lv
On the Settings tab, expand point, expand Commands, right click on CreatePoints, Edit Feature Settings...
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Member
t2lv
Message 3 of 15 (1,061 Views)
04-19-2012 11:59 AM in reply to: TRogers
My settings are identical except for the point number, but I cannot get the point numbering to change. I have no problem in 2012, but this is my first go around in 2013. My partner gets the same results on his updated workstation. I have attached a clipping.
TRogers
Message 4 of 15 (1,055 Views)
04-19-2012 12:06 PM in reply to: t2lv
In your create points toolbar, expand the chevron to the right and make sure that the point number states 5000.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Jeff_M
Message 5 of 15 (1,050 Views)
04-19-2012 12:12 PM in reply to: TRogers
None of the Point Creation commands, that I've tested, in 2013 honor the next point number property. Another bug discovered.
TRogers
Message 6 of 15 (1,047 Views)
04-19-2012 12:14 PM in reply to: Jeff_M
it works fine for me.  You must make sure that the Next point number is set in the Feature Settings and in the Create Points toolbar.  If it's not working, can you post the drawing so I can take a look at it?
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Alfred.NESWADBA
Message 7 of 15 (1,041 Views)
04-19-2012 12:28 PM in reply to: Jeff_M
just tried it with "manual point" and Civil3D 2013 German .... works for me (see video, maybe there are different workflows, command-calls, clicks, ... that makes the difference).
- alfred -
Alfred NESWADBA
Jeff_M
Message 8 of 15 (1,037 Views)
04-19-2012 12:35 PM in reply to: Alfred.NESWADBA
OK, Manual does work. The Automatic, On Line/Curve, and Polyline Vertices - Automatic definitely do not.
TRogers
Message 9 of 15 (1,034 Views)
04-19-2012 12:36 PM in reply to: Jeff_M
Good to know.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Member
t2lv
Message 10 of 15 (1,028 Views)
04-19-2012 12:46 PM in reply to: TRogers
I can control the point numbering fine for a single manual point setting, but when I pick a polyline to set points automatically along the vertices, it returns back to ignoring my settings.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
